- Joined
- 30 Oct 2006
- Messages
- 6,743
- Reaction score
- 367
- Country
thats great information thanks.wheres the best place to pick up a variety of seals? i tend to use some foam wrapped in silicone as a stop gap for small gaps in casing but would much prefer a delection of case seals.
i would stop that right now if i were you. using anything other than the correct manufacturer seal for that model of boiler is asking for an arse kicking. no doubt the lurking dodgers on here will disagree but its asking for trouble, particularly on positive pressure boilers. if the seal is buggered then AR or ID as appropiate, dont chance your freedom or a customers life.
just one more thing regarding these boilers. invariably the boiler is in the corner up against the wall or squeezed between two cupboards so you cant possibly test the sides of the boilers for leakage. thats really my point, u can test the corners but not the sides because some installer hasnt left sufficient clearences around the boiler
all you need to do is record the fact that you cant test it properly. as long as you have done everything you can possibly do to test its safety you have covered your arse.
