The invoice for the fitting of this boiler is dated 14/03/04 it also states supply & fit Potterton combi 80, the instructions manual supplied is for a Potterton combi 80 so in answer to your question I would say "yes I have quoted the correct boiler model"The boiler is a potterton combi 80 and was installed 4 years ago
4 years ago?? are you sure you quoted correct boiler model?
Nice to know ive been ripped off by another reputable corgi registered expert in who we should all trust.Does it have 2 rocker switches on the left?
If so it's just a facelifted version of the Puma. Electronic ignition, no temperature controls and no water pressure switch. It was prrobably lying in the back of the merchants since they are normally older than this.
Bit early for a diverter swap though ...you sure that's the problem and not dripping hot taps/minor leak.
Tried that already , no changeTemporarily isolate the cold feed to the boiler and see if the heating improves.
Do a search on Puma diverters...all info there.
