Potterton Performa 24 DHW Issue
14 Oct 2010
Hi everyone
I have an issue with the above make of boiler. Basically 2 symptoms
1. when turning on the hot water in the bathroom it is only luke warm. Can be made scolding hot if the tap not on full force.
2. When tap in bathroom is on full force the rads start to heat up.
I have done a bit of research and it points to either the Plate HE or the diverter valve or both.
Questions! If the Plate HE is blocked is this easy to remove and clear?
Second, if the diverter valve is faulty will the whole casing need to be replaced or just the diaphragms inside?
Would it be the DHW valve or the CH valve which is faulty?
Dante
It sounds as if the whole diverter valve needs replacing.
But thats only based on what you have said! You have not said that it does not fire up on DHW when the heating is off!
While doing that the plate HE can be checked and cleaned.
Most boiler repairs like this are fiddly but achievable.
Thanks Tony.
Sorry I dont understand your last bit. The boiler fires up for both HW and CH but only luke warm DHW.
C
Yes, thats the senario that I replied to.
Yes that is the scenario. Sorry I am easily confused :D
When I moved in to the house the pressure differential had been leaking, where the pushrod is. I replaced the valve in that and all was sweet.
Final question.
Is the the only part I need to buy?
http://cgi.ebay.co.uk/potterton-mai...543108465&po=&ps=63&clkid=7291880088259792514
or do should I think about replacing the differential valves (bit with the pushrod, I don't know the lingo)
Pic attached or in album !! ?!?!
//media.diynot.com/151000_150624_31468_85286815_thumb.jpg
I will have a look at the plate when the valve is off, my Dad was a BG engineer for a fews years so I feel fairly confident!
what tony ment was if you have the boiler on hot water only does the water heat or do you have the heating running while you turn the tap on.
i assume it works when only hw is on and would therefore guess its the main diverter valve that needs replaced as its passing. you could ask your dad to look at the colour of the system water as it could be related to poor water quality (choked up)
Ray
