The expansion vessel in my Potterton performa 28i has failed, water coming out of schraeder valve. Reading the very helpful advice on this forum I decided to fit an external expansion vessel teed off CH return with 15mm pipe into 3/4 female. The vessel is located beside the boiler so bottom of vessel is approx in line with top of Boiler.
The pipe work enters at bottom of vessel and schraeder is at top. According to the label it is upside down. It had 1.3 bar pre charge. Prior to fitting vessel boiler worked fine unfortunately now the burner is not igniting and the low pressure fault / pump fault light is flashing, the pump is spinning and becoming warm and the guage shows the pressure as 1.5 bar, is an air lock in boiler causing this ? The boiler is making unusual sounds - grinding gurgling sounds as if trying to push water through. I recently changed a small rad 600x600 and fitted an angled valve with drain cock, the property in question is a flat with a total of 5 rads. I've spent several hours and am totally flummoxed, all advice greatly appreciated.
Tommy
Tommy
