Hello,
Can anyone help?
We have hot water which is running normally. However, when the CH is switched on it ignites and runs quite normally for around 8 mins or so at first then makes a rather loud bubbling noise sort of bangs and then shuts off tripping the reset switch.
I have bled the system as I thought there was air in the system.
Once you switch the CH back on again it comes on again for a few minutes and then trips again.
Only the rads first off the run are getting 'slightly' warm the others are staying cold because heating is not on long enough to warm them.
Someone suggested the pump, but surely the hot water would not be working if the pump was not working would it?
Any suggestions would be greatly appreciated before I have to call someone out.
Please help quickly kids are moaning about cold!!
Cheers
Can anyone help?
Cheers
