potterton profile 80e
11 Dec 2012
Dorset
changed pcb and ht lead,so far.
seems to work ok until its been hot for a bit ,then when termostat wants it on air fan spins then sometrhing clicks, air fan stops,then tries again .has already burned out 1 fan.
Mr Lewis, there seems to be something significant wrong with your boiler.
Please call a gas reg engineer to check it out for you.
Tony
:) weymouth plumber required to fix a potterton 80e.boiler works 0k but stops as if reached temp, but later tries to start again but fan keeps hunting, does fire eventually but tends not to fail when a plumber looks at it.
hot water pressure not good drops to a trickle until topped up with the higher pressure cold water.dont know if this is linked?
any advice?
I dont know who he is but my friend there gets Gas Certs for only £25.
I think its somebody in Wyke.
But I dont know if he does repairs too.
fitted new air switch same prob,briefly remove red pipe fires up replace pipe, what does air switch protect?
