- Joined
- 23 Oct 2021
- Messages
- 13
- Reaction score
- 1
- Country
I’ve got a Potterton 12SL Promax condensing CH boiler, It would be great if someone could give me some advice to resolve this problem, I was having problems with the boiler where I was getting the Dry-Fire warning lights on the fault finding. I’ve recently changed out the flow switch as well, When I changed the flow switch out, There was a lot of black gunk attached to the magnet on the magnet swing gate inside the flow switch. I’ve been having further problems since changing the flow switch. It worked well for the first day but today it started locking out. After firing up & working for 5 minutes, The water coming into the boiler is noisy. It was cutting out & all three lights were out on the PCB housing & the reset switch wasn’t working. For me to fire it up, I had to turn off & turn on the fuse coving the boiler on the house main fuse panel. The boiler isn’t flicking the fuse. I need to turn it on & then of myself. It fires up each time after resetting the house fuse but cuts & locks out after a few minutes. I would appreciate any advice to resolve this problem. Thank you in advance. Richy
