Hi all
Intermittant fault in that it will not fire up. It can be working fine the night before but when its due to come on again (on timer or manually) it doesn't.
The power light is on and you can hear and see one of the relays click and the fan starts but thats it. The green light doesn't come on. No heating or hot water. It can happen whether you just want heating or hot water or both. Have noticed that if you switch between <Constant> and <Timer> on the <Central Heating> switch the green light comes on for a split second. Eventually the heating will come on. It could be a few minutes or several hours but then it works fine.
Thanks for any advice
vic11
vic11
