The holes in the substrate are too large and do not hold the pin firmly thus leaving the solder to form the mechanical as well as the electrical connection.
Normal flexing of the PCB and connections cause the solder to crack and arc thus eventually destroying the joint.
If Potty had fixed it with a new version when the problem was first recognised it would be called a 'design fault'. After the years of revenue from replacement boards which were also cr*p, I'd call it 'planned obsolescence'.
When design defects in electronic products are manifested during the manufacturing process, the faults that occur tend to be the same. Why do you find this strange?
