My problem started due to pressure dropping, mainly when boiler was not in operation(heating off) and didn't seem to drop when the heating was on. I phoned the insurance company up who sent an engineer around who diagnosed a fault with the expansion vessel and also replaced the PRV. I would like to point out that the expansion vessel was faulty and full of water.
He went and yet the problem was still there(pressure dropping) and would go from 1.5 bar to around 0.3 bar over night. I than started pulling my house apart looking for a leak in the system, floor boards up the works. I was tossing and turning going out of my wits with worry due to a possibly hefty bill. After a month of worry I thought I would bleed the radiators and drain out the system, although the water was dirty I definitely had seen it worse in the past. I am not trying to plug a product here, I then put in 1litre of Sentinel X400. In order to drain the system properly, you need to open the bleeder valves when draining to let all water properly drain out before opening filling loop to run clean water through the system. Once the Sentinel x400 was in I topped the pressure back up, bled the radiators and then ran the heating until bedtime (21.00 hrs) no pressure drop. When I woke in the morning I checked the pressure, dropped yet again.i Topped back up for the wife and kids to get hot water and heating while I was at work. I phoned the insurance company up during the day and the engineer came around 17.00hrs and checked the pressure, no drop !. Boiler sorted, has been fine for days. In fact it's running like new.
