Hi There,
I have a Prima dishwasher that is not cleaning properly, in fact it appears as though the contents have barely been cleaned at all on both top and bottom racks. Also, I use Finish tablets and this remains intact too, almost as if there is not enough water circulating to dissolve the tablet.
I can confirm that there is steam coming out of the machine when the door is opened at the end of the programme, so it appears as though what water there is does heat up sufficiently. It also sounds as though water is spraying around but I can't tell if this is enough.
I found the diagnostic sequence on the web and have run the machine in the diagnostic mode, but not faults have been indicated.
Also, I noticed that the sump still had some water in at the end of the programme, so not sure if it's draining properly.
I have removed the dishwasher so does anyone have any suggestions as to what to check. I have a multimeter.
Thanks in advance.
Robert.
Thanks in advance.
Robert.
