Looked at a CH system today which has been left half done; plumber did a runner - and after having a good look round think there may be some fixing to do.
There are 22mm F&R pipes branching off to all rads but the downstairs hallway rad completes the 'loop'. 22mm Flow reduces to 15mm and drops down as does the return. Will this create a problem when running the system as the flow will squeeze down to 15mm, through the rad and back up from 15mm to the 22mm return?
All rads have TRV's fitted so I'm thinking if the hallway rad is turned off it will need a bypass fitted somewhere but where? Just before the last rad or near the boiler before any rads?
If anything isn't clear just ask. (It confuses me)
