I had my system Powerflushed last week, and whilst all was fine for the first few days (less noise, radiators hot), after a couple of very cold mornings I am now suffering from banging and gurgling noises in the pipes and boiler about 30 minutes after the boiler is switched on.
Another major problem that has developed is that the hot water tap downstairs is now suddenly down to no more than a trickle, with the others being fine.
I spoke to the heating engineer who did the flush and he advised me to turn the boiler thermostat down slightly as the pipes may be getting too hot. I tried this and it helped a bit but not much, but on reading up it seems like the thermostat should always be set to max in the winter anyway.
Has anyone else noticed similar problems after having a powerflush, or can anyone point to the possible causes of the noise other than corrosion? (which should no longer be an issue!).
The heating engineer had to remove my hot water cylinder for some reason during the flushing process - do you think this could be related to my problems in any way?
I have a back boiler (baxi bermuda).
