problems with water drainage in dish washer
Discussion in 'Appliances' started by Halloween Jack, 6 Apr 2012.
  1. Halloween Jack
    31 Mar 2006
    170
    Thanks Received:
    Country:
    Hi folks,
    We have a AEG 60860 which is coming up with a .20 error, apparently a water drainage issue.
    Sure enough there is un-drained water at the bottom.
    It mentions check the sink outlet... what is this?
    I guess it's blocked somewhere but I don't really know what to check.
    Any suggestions?
  2. Hugh Jaleak
    3 Feb 2008
    4,759
    Thanks Received:
    901
    Northamptonshire
    Country:
    Where does the drain hose from the dishwasher go to?
  3. Agile
    26 Jun 2004
    61,279
    Thanks Received:
    4,283
    London
    Country:
    There is a pump and probably some kind of grill or filter on the inlet to the pump.
    Check pump is rotating and inlet is clear.
    Tony
  4. DP
    DP
    10 Dec 2003
    9,073
    Thanks Received:
    1,342
    Glasgow
    Country:
    OP
    Are you sure? Check when machine finishes cycle. And then a while later.
  5. Halloween Jack
    31 Mar 2006
    170
    Thanks Received:
    Country:
    Hi there,
    There are 2 hoses coming from under the machine, one goes to the sink drainage, I guess this is the drainage.
    There is a filter in the bottom I can take this out but I can't really see much else. I can't see anything that rotates or an inlet.
    I can't start or finish a cycle, it just stops with that message.
  6. Agile
    26 Jun 2004
    61,279
    Thanks Received:
    4,283
    London
    Country:
    Its also possible the water level sensing tube is blocked.
    To access the pump you probably have to lay the machine on its back and do it from underneath.
    Perhaps its better to call a repairman?
    Tony
  7. Halloween Jack
    31 Mar 2006
    170
    Thanks Received:
    Country:
    Ok thanks all, i'll look into all that.
    Thanks for the help
  8. Servotech
    19 Nov 2009
    340
    Thanks Received:
    41
    Nottinghamshire
    Country:
    A lot of washers have a filter on the front - usually accessed through a little door below the machine door 1/4 turn then pull it out and clean it (have some old towels ready to soak up the water that will spill out).
    This fits the fault you described to a T.
  9. Agile
    26 Jun 2004
    61,279
    Thanks Received:
    4,283
    London
    Country:
    I think we can take it he has checked that.
    Still leaves the sensing tube or level switch or even the pcb!
    Tony
  10. denso13
    22 Jan 2007
    2,369
    Thanks Received:
    439
    Country:
    Maybe try the appliance section of the site?
  11. Halloween Jack
    31 Mar 2006
    170
    Thanks Received:
    Country:
    Thanks all, I'm still struggling with this. The service company want over £160 to fix.
    I have just noticed the appliance section here, thanks, I'm going to repost there.
    Cheers
Loading...
Share This Page
