I was curious as to why this might have started happening and was fiddling with the actuator on the mid position valve this morning. Is it possible this has become "lazy"?
After reseating it on the valve, the voltage I measured as 120 last night is now 80 and the boiler isn't staying on unnecessarily any longer. I have a feeling this isn't a permanent fix though...
It's extremely stiff and can only be turned with a wrench. I've found a "silicon oil" spray that I applied about an hour ago and it hasn't improved it.
Well everything seems to be running ok for now, have tested various combinations of CH and HW on and off. Will keep an eye on it, but at least I know what the issue probably if it recurs. Thanks all for your help!
