1) Boiler make / model (gas or oil)
Protherm 80e Gas Combination Boiler
2) What is / is not happening.
When the front panel is closed the system shuts off, lights out. When it's open again it briefly displays -2 before then displaying the temperature.
Currently the on demand hot water is working just fine as expected.
The heating comes on if it's left on for long enough. Prior to this issue it used to come on as soon as turned on. Water temperature and radiator temperature is good.
3) Has ANYTHING else been done or changed recently.
Corgi Service engineer came to service boiler, the pressure was around 0 before he did this. It's now back up at around 1.5
4) When did the problem start?
When he tried to service it. Sorry if this sounds like I'm blaming the engineer that's not my intention.
5) When does it happen? eg, heating coming on or going off.
When the case is closed (or flexed)
6) Anything else you feel may be of relevance.
Nothing was operational when engineer left but tweaking the power and temperature limit pots got it operational again (apart from the above problem).
Boiler is approx 9 years old, was last serviced in 2005 before I bought the house. Some people believe this to be a CZ boiler but my manual gives an address in Derbyshire. I also found this on another forum:
"Originally the Protherm 80e was made by Glow Worm for Travis Perkins. Travis Perkins have changed supplier so no longer stock any of these boilers / parts."
I intially thought that closing the case was putting strain on the wiring loom but I've not seen evidence of any loose wiring. It's possible that the main card has a dry joint or hairline crack that goes open circuit when the panel is flexed but there's no obvious visual issue.
Main PCB is V2.0
Does anyone know a friendly North London gas engineer who is happy to work on an Protherm 80e (with or without bargepole)? I believe there's a handful of suppliers out there who can supply a replacement board if that's needed, I've contacted one of them and I've also contacted Glowworm to see if they can supply spares.
Main PCB is V2.0
