ptching up walls
17 Dec 2002
I own an old house which unfortunatley has very bad walls. I was wondering what is the best compund to use to fill holes made when plaster cracks and falls off. Also how do i get the filled area smooth and level with the existing walls :oops:
Any help is nuch appreciated.
You may need to remove the old plaster till you get to solid plaster, take the old plaster back to the house brick, them with a mix of 3 sand to 1 cement do a rough coat, let it dry till it goes a grey colour, then mix your plaster one coat plaster is best, mix till it is smooth and creamy, use a hawk and a plasteres trowel, and in one motion plaster the rough coat cement, to make it smooth have a bucket of cold water and a brush to hand, wash the trowel off but dont dry it, with a little water on the trowel go over the plaster again, and you will get a smooth finish dont flood the plaster, then when you have it as you want it, let it dry for two weeks, before painting or papreing.
