I live in a block of flats (there's 6 of us). Today, I noticed that an exterior overflow pipe that we share is continuously dripping.
I have contacted the management company. They advise that we will all have to hire plumbers and investigate what the problem is (as it will be a problem originating from inside one of our flats).
Is there any way for me to easily rule myself in / out of being the cause?
We all have PULSACOIL III electric hot water heaters. The dripping water (which is above my flat -- and which I can just about reach -- is lukewarm. So I could guess it's coming from someones PULSACOIL.
I have done the following:
I could also drain the water heater. And see if the leak continues?
Otherwise, is there anything I can easily do? Thanks a lot in advance.
> turned off my mains water tap and opened taps and toilet.
The leak continued.
> checked hot water
No obvious loss in temperature or pressure.
The leak continued.
> checked hot water
