I have a celsia multi-head Myson single pump on a four bed house connect to a Potterton Supima 60F boiler. Three port valve. There are 12 radiators (some large doubles)
When I turn of the system all is ok except some rads don't seem to get enough juice (I have balanced the rads as best as I can). The pump speed is set to 1. If I set the pump speed to 2 or 3 the expansion pipe starts spitting like a cobra.
I suspect there is a sludge build up. How can I sort this out easily without a power flush? Any ideas as to what is causing this problem.
And is this boiler/pump powerful enough? I have worked out the rads in the house are approx 62,000 BTU and the boiler has a max of 60,000 BTU.
Cheers
Cheers
