I've just moved into a rented flat about a month ago and the shower is driving my girlfriend and I crazy.
It is a standard bath / shower mixer tap that seems to have both the hot and cold water being fed by a pump under the bath (both the cold and hot water taps will start the pump). The hot water is fed by a combi boiler that has not DHW temperature adjustment and the cold I assume is mains fed as there is no tank. Cold water pressure to the basin is a little low I must say.
Trying to balance the temperature of the shower is like trying to crack a safe! The hot water overpowers the cold quite easily and the temperature becomes scalding.
There's nothing I can do directly as the flat is rented but is there a device that I can recommend to the landlord that could be fitted to better balance the temperatures? Maybe there's a way to adjust the flow rates at the pump?
Any ideas would me much appreciated! We're going mad!!
