Before you install this panel I would Check the aux volts output and battery output as these are a common problem for high voltage outputs.
That control panel has not been manufactured for many years and the time involved in fitting ,sometimes you would be better buying new.
The only reason I have it is because I got it for 20 quid, with pirs and a bell box. It is for my shed so no need to get anything flash. I would get a cheapo key alarm but I have had ussues. Thanks for your help!
