Reading the Engineer Manual for the Sterling 10 .....
The panel can be reset to factory default by shorting out the NVM reset pins & powering up the panel -ok, fairly standard.
The manual goes on to say that if this doesnt work then Engineer Code & NVM Reset has been enabled..... enter Engineer Mode, open cover, short out NVM pins, press FUNC 2 9 and the panel will reset....
BUT ... I need to reset the panel because the engineer code is unkown ...... so, I am locked out of this system or is there another way to default this panel.
(I havent yet tried this..... I wanted to be sure first ... didnt want to be stuck with a system I cant reset)
Adrian
Adrian
