had a problem with one radiator in the house for a while now. when the heatings on all radiators heat up fine and work perfectly, the living room one never heats to the same temp as the others, even if thermostat is on full it will only be warm at best.
thought i had found the problem when i spotted the TRV had been snapped when the chair pushed against it, ive replaced it today and refilled the system but still the same problem. the pipe and valve going into the radiator are boiling hot but the radiator itself and the valve and pipe at the other end are just warm. a while ago (2 years) we had a problem when the raditor had been bled and the valve not tightened properly and it had leaked without anyone noticing and had rusted in the top corner, not sure if that has now caused a problem inside the radiator ??
any advice or ideas on what could be the problem and how i can rectify it, thanks a lot
