Hi guys,
I recently moved to the top-floor flat of a 2-storey building and there is very very poor water pressure (both kitchen and bathroom) due to the close proximity of the water tank in the loft. It is less than 2m far from my hot water storage cylinder which is located in the airing cupboard in the bathroom.
I repeatedly complained with both ThamesWater and the property management company to obtain a better pressure from the mains but it's all uselless. ThamesWater is only responsible for supplying water to the ground floor where the pressure at the stopcock is 1bar or slightly more.
Obviously, once the pipe reaches my flat there is inevitably a bit of a loss and I won't be able to install a megaflow system.
I was advised to replace the existing shower pump (which is broken) and raise the tank in the loft by 2m. There is a lot of room in the loft and I can raise the tank to a maximum of 2 metre.
How much would I gain in water pressure / bar by lifting the tank? Do you think 2m would give a better pressure and flow? Perhaps I should also replace the cold water pipe with a 28mm one?
Also, I'm not sure whether I need a negative or positive pump. As I said the tank is in the loft and the hot water cylinder in the airing cupboard in the bathroom.
Should I get a Stuart Turner Monsoon positive or negative?
Thankssss!
P
Thankssss!
P
