My plumber advised me to replace the existing water tank with a bigger one as I'll be using a much larger cylinder with 166l capacity. What sort of larger tank would I need then? And how big?
As I told you, he plans to lift the tank by 2 metre with a wooden base. Anty tips on how to build such a high platform? Is wood the right material to support the tank?
I would hope your plumber/fitter would know what he’s doing regarding construction. Basically it’s a large table but it must be of sufficient strength & cross braced to support the weight & suitably supported over the rafters. I would use 4” x 2” for the platform & minimum 18mm WBP for the ply base fully supporting the tank base.
As for the shower head, is the one below good enough? It's a Grohe Rainshower and apparently it needs at least 1.0 bar pressure... my pump will be a Stuart turner Monsoon Universal 2 bar twin. Is it ok? Would the system work?
That would be OK but as I said previously, if you fit an angled shower head over a bath, your going have water everywhere when you shower. I always recommend something that points directly downwards over a bath; http://www.taps4less.com/PP/U-A3241.html
Last but not least, I have some disgusting smell coming from the cupboard below the basin. It looks like my toilet is connected to the basin with a flexible pan connector like the one below:
I don’t really understand how the loo can be connected to the basin; do you mean the other way around? Flexy connectors are not ideal & I don’t see how yo can connect a basing waste into one, can you post a photo?
I'll post some pictures of my bathroom asap. In the meantime I was wondering whether I should get a Foam Lagged Hot Water Cylinder or a Steel Ace one. Gledhill produces economy 7 cylinder in both materials. The Steel Ace ones are 100 quid more expensive. Is it worth the money?
