the house we moved into has this boiler already installed with the instructions etc left with it ,
i had to remove a radiator from the wall so the plasterer could get behind
this obviously dropped the pressure on the boiler ,so i refilled the boiler upto 1 bar , since this about a week ago the boiler has been acting up
every time you use the hot water the boiler fires up but when the water heats up it shuts the gas burner down till the temp drops ,then restarts the burner ,causing colds spots in the water which obviously hinder filling the bath etc .
the boiler seems to have stopped modulating the hot water temp , no fault codes except before refilling the boiler (not from empty just topped up ) when i removed the radiator , which was code 04 Failed overheat
but that code is for the heating not the dhw and the heating is fine
