is it easy to change when i have the part. I am fairly competent at DIY, i ve changed a CH pump at my mothers and all works fine.
and is the Diaphragm found in the diverter valve?
I've had my CSI to bits loads of times (I'm not CORGI registered or part P) and I'm still alive! Living with this boiler is really a labour of love.
The diaphragm is best removed and examined first to see if it has perished or split (or has some crap which is causing an issue) Simple thing to take apart and replace. If it’s not perished or split then it’s not the diaphragm.
Things I have learnt the hard way:
Its always simple parts that go! This means thermostats. I now consider these routine replacement items.
They do stop the boiler from lighting (or remaining lit) it's their function.
The fan either turns or it sticks. If it sticks, then oil it.
The issues I have found many times are the seal on the front face. If too much air is being sucked in, it cuts out.
PCB is of quite poor quality with very inexpensive components.
The PCB hates water but because of the very low voltage across it, you can get away with a lot.
I always (twice a year) remove the heat exchanger (DHW) and fill it with powdered citric acid and leave it for a couple of hours. This is amazing stuff and cleans a lot of crap (and is great for any brass fittings)
The gas valves are Honeywell so they are good quality and should never really go.
I do have a very strange thing going on at the moment which is this:
Morning times, DHW with immediate effect.
Afternoons (warm) then kitchen feed is not igniting the boiler and will run straight through but if I turn on the bathroom taps, it runs hot!
This has to be something to do with the PCB when heated it expands and is maybe causing a short.
Still I can't imagine life where I was not involved with my CSI at least every month
