Morning all,
I'm still having some boiler problems so thought I would come back for advice.
The symptoms are that I start the heating, the flow pipe gets nice and hot, radiators start to warm up and then the boiler cuts off after a short while, restarting after about 10 seconds. The cycle continues for about 1/2 hr but during that time the length of time that the boiler is running diminishes and the off time increases. After about 1/2 hr the orange flame fail light comes on and the boiler trips out. I reset it by turning it off and on.
The fan and the pump continue.
There are no issues with DHW and we can fill a bath of water.
Initially we thought it could be air in the system as I had not opened the air valve on the boiler but this proved not to be the case.
Next suggestion was a faulty thermostat which leads to my next question - Using a multi-meter how can I establish if its the stat causing the trip, what sort of voltages should I be measuring across the thermostat terminals.
My other thought was that the pump may be faulty and not pumping fast enough to keep the water flowing - Do pumps work slowly if they are faulty or do they just die.
Thanks in advance.
Stu
Thanks in advance.
Stu
