Hello,
Before I rip up all the carpet, I have a 30 amp RCB on an upstairs ring main and it keeps tripping off with a small bang. We had carpet fitted while I was away and I can only think that they have knocked something loose under the floor boards. It doesn't trip straight away, normally takes a min or two? I have replaced the breaker for a new one but it's the same story.
I have been round and unplugged everything on the offending ring main, but is there any way of checking plug sockets etc before I rip up all the carpets and floorboards to find a loose wire ? I have had a look inside each plug and the wires are all made off correctly.
Is it worth checking for continuity between RED/BLACK/EARTH back to the fuse box from each plug in turn in the hope of finding a loose connection?
What normally causes an RCB to blow after a min when nothing is plugged into the ring other than a short (should than not blow straight away?) or a loose wire ? (i.e. open cct).
All info greatly received.
enjoy,
Steve.
enjoy,
Steve.
