Indeed - and if he used 4mm² cable, there wouldn't even be a need for the FCU (which I presume is what you mean by "fused spur").yes, no need/point in changing MCB if your fitting a 13A fuse spur
True (at least in theory). However it sounds as if little, if any, of the cable would be 'outdoors', since ...T&E isn't suited to out door use, unless inside something
Presumably around half of the "1/2 metre" will be the thickness of the wall itself, leaving very little!... thru the wall 1/2 a metre away
OK but did you ask him what reg (number). Did you point out that the regs are not statuary anyway?Said wasn't allowed under new regs to change cooker circuit to other use and would need new
cable run for shed.
Just tackled electrician,
Also need 32A MCB replacing with 20A MCB in CU.
