Recommendations for a good Forstner bit (15mm)?
24 Sep 2011
Nottinghamshire
Can anyone recommend a good 15mm Forstner bit? I've seen some in ScrewFix - some with bad reviews, some with average. I want something that can cut a few dozen holes in hardwood (Wallnut, Oak, Ash) without noticeable deterioration.
It's to cut holes for Cam & Dowel fittings. Seems to be the right tool.
Oh, any tips on getting a hole where I want it would be good too. My centre mark usually slips half a millimetre when I strike the centre-punch.
Look for Clico (British), Famag, Colt, Festool Centrotec or Fisch (all German). Avoid cheap Chinese cr*p because it doesn't work, stay sharp or drill true. Forstner bits always were expensive - good Forstners still are
Yes. Use a drill press and a home-made jig! That way your hole will be perpendicular to the surface as well. Failing that mark your centre with a fine awl or an ice pick rather than a centre punch designed for metal. If your eyesight is bad get yourself an auxilliary clip-on magnifiers
Thanks that's really helpful. That seems a good store too. I think I'll pick up some stuff :)
It has a hex shank. Can I put it in a regular drill? If so, which part of the shaft should I clamp? The wide bit or the narrow bit between hat and the hex?
Thanks again. Obviously not used one of these before! :D
Clamp onto the hex - a 3-jaw chuck will do that easily. The Hex shank also allows you to install the cutter in a bit holder
D4lSylnAquGLA1_QgQ9OYQTcwq_wCprERM6-Bd7xDvnkMB05AiFS0s0JI3Q7nCPSVILkp0-V6cTZ_KIgApOqGZScm8SGhEQUPZNXQOq9rN2ZPuZVTo8GOyE1trntaNXAcpRGe4Mn_tXoi5IBaX9LCzqkj6bXdXrEuP4VUaToapnIvqFdC8yHc0DHYto4lw
so that you can change quickly from drilling to, say, screwdriving
