Does the switch attach on to the push pin or does the pin belong to another item that the pfs sits on? just wondering because its the pin that keeps getting stuck.
The pin isnt getting stuck. Its operated by a rubber diaphragm underneath it. This is probably worn and needs replacing.
To access you need to drain the boiler. remove the microswitch in the plastic box by removing the black retaining clip. Then lift off the cover plate by removing the 4 screws. Bare in mind one screw is obstructed by the gas valve and even a little dumpy screwdriver is awkward!
personally i think you need to call someone out as its not that easy.
So what you guys saying? how can i tell exactly which problem it is?
The PFS seems to work fine but the pin seems to stick and i would hazard a guess that the micro switch seems to be operating fine, so the pin isn't part of the pf switch? so in that case how do i diagnose the "sticking pin problem"?
