- Joined
- 1 Sep 2015
- Messages
- 368
- Reaction score
- 5
- Country
We've had a bit of work done on our house, and the main part involved a new kitchen.
With this, the lights have been rewired so that we have different rings and switches. In addition, we've also had a new feed put in for the hob (to the CU) and a few other bits and pieces.
Other bits around the house included swapping wall lights for down lights, or just adding more lights to an existing ring.
From the start, I knew this would have to be Part P signed off which is fine. However upon completion of the work, we are now being told that because our consumer units is 16th edition, it must be swapped to a 17th edition so that the new circuits in the kitchen can be tested and signed off as Part P.
Is this correct or are we being ripped off here? I was under the impression that any circuit, Part P sign off or not, could be tested on a "non up to date" consumer unit.
Also, if a new consumer unit is installed, this means a full house test is required, so do we also need Part P sign off for the kitchen, or is this now covered under the full house test.
Would appreciate some advice from a qualified electrician so I can find out if we're being duped for another £350-400 when a £150 Part P is enough.
Appreciate there are probably some details missing, however any general advice would be great.
