Moved into my house a few weeks before xmas 2005 and the property has a Range Powermax 155 boiler.
Soon after moving in we discovered that the heating and hot water went off and the pressure gauge on the boiler was zero. After phoning someone about this they said to use the filling loop on the side to restore the pressure to 1bar. Everything was fine after doing this and we had heating and water again.
The problem is that the boiler does this on a regular basis, 2-3 times per week sometimes and after reading some of the posts on this forum I believe this is somewhat unusual and means there is a leak somewhere, although I haven't noticed any leaks!!
What I have noticed is that the drop off in pressure can be quite rapid rather than gradual. I'm at a loss at the moment as to why it would be doing this. The other problem I have is the previous owner didn't leave a manual.
Other than phoning a plumber, any advice would be gratefully received.
TGC
TGC
