Hi, after some advice on my boiler please, Remeha Avanta 28c.
Boiler was switched off whilst house was being renovated, was working fine before being turned off.
Radiators were drained/removed during this however pressure gauge was stuck which turned out to be faulty, replaced with a new one. Filled up and bled to remove air.
When switched back on, it was totally dead.
PCB replaced and boiler has come back on however its showing an error code of 9.
Boiler has pressure of 1.5 Bar.
All of the information, including the manual, I can find says it is due to low pressure however pressure is correct but it still wont fire up.
When turned on it goes thro the start up procedure but thats it, if hot water tap is opened or heating turned on then it shows a 9.
Any advice would be appreciated.
