Rendering a white washed / painted wall
19 Mar 2004
does anyone know the best way to remove the paint before rendering? Does it have to be removed? :confused:
You could wire brush it or jet wash it at close range but it may pull the pointing out too. If it is still there after a rub down with a wire brush then you can safely assume it will be ok to PVA the wall and render over it.
