D
Deleted 205484
I am having my roll top cast iron bath re-enamelled but when we took it out, the pipes got bent. We have just bought the place.
The two pipes from the floor have 15mm shut off valve (t-screw) fitted and then the pipe connecting to the taps is 15mm copper up to the tap where it goes to 22mm and connects to the taps.
I want to keep the taps (traditional style) so I want to cut out the bent bit of pipe and then connect a 15mm screw connector to the inlet valves to a 15mm speedifit connector on the pipe.
Is this the best way and could I use these.
http://www.plumbcenter.co.uk/en/plu...r-flue-pipe-connectors-15-mm-15-mm-pk-2-20070
