Replacing a mixer shower, help!!
22 Mar 2011
Kent
Hello all,
My mixer shower is faulty and I've just bought a new one online. I currently have a Croydex H2O which I've had nothing but trouble with and so I've finally decided to replace it. I've just bought a Trevi E9105AA venturi system. Does anybody know if it will more or less be as simple as swapping the two showers over? Will the connections onto the hot and cold pipes be the same? I've chosen this particular shower because it's the closest I can find in terms of the distance required between the hot and cold pipes.
I'm new to this plumbing lark so not sure if the connectors are pretty generic or if there are loads of different types?
Thanks in advance.
Adam
The standard distance center to center of pipes is 150mm. They are both Venturi style showers so you should have no issues installing the Croydex.
Pete
