I have a Hager consumer unit which has a Hager Rcbo 10amp ADB110 fitted.
This is for an outside double socket.
Sometimes this will trip because of the drill etc being used.
I am to buy a Hager Rcbo 16amp ADB116 and swap it over.
With all this Part P now is this ok for me to swap it,doesn't look hard at all.
Whilst i am doing this i wish to also install a double socket inside the garage & would like to also have this Rcbo 16amp cover it.
Do i need to make connection in the back of the outside socket or can i use a junction box inside and make the connection.
The wire in use at present is grey flat wire 6mm
Please advise thanks.
