replacing single room thermostat with programmable trv's
Discussion in 'Plumbing and Central Heating' started by a13exf, 1 Apr 2012.
  1. a13exf
    1 Apr 2012
    4
    Thanks Received:
    Staffordshire
    Country:
    hi sorry if this has been asked before i tried searching but couldnt find anything.
    I want to replace my trv's with programmable ones so that I can controll the temperature in individual rooms at different times of the day etc.
    currently i have a timer / programer in the kitchen that I can set when the entire system is powered up. and a room thermostat in the hall that has the ability to turn the entire system on and off.
    I want to install the programmable trv's and then have the central heating system turn itself on and off when the programmable trv's open the valves to heat the room. my system has a separate boler and pump, the boiler is also set-up to heat the hot water.
    my thought was to use the power input from the room thermostat in the hall and replace it with the pressure swith output.
    does anyone know if this is possible and whre i might find this type of valve.?
  2. 45yearsagasman
    14 Mar 2010
    5,894
    Thanks Received:
    1,036
    Norfolk
    Country:
    So you're going to introduce some control wiring to each of these valves so that any one can switch the heating system on or off? :confused:
  3. gas112
    27 Oct 2009
    12,326
    Thanks Received:
    3,124
    Country:
    So are you laying out all this money to save on gas consumption if so its going to be a lot of lot of years before you have pay back
  4. UpgradeME
    6 Feb 2011
    230
    Thanks Received:
    26
    Country:
  5. Dan Robinson
    1 Jul 2007
    43,987
    Thanks Received:
    7,138
    Hertfordshire & London
    Country:
    You need to use the roomstat to bring on the boiler, but programmable trvs can be very effective.
    Evohome will never be cost effective in this configuration due to the cost of the valve heads.
    I speak with experience of both.
Loading...
Share This Page
