Roof under window cill
Thank for that one freddy. Its a balls up and there is no magic solution that I can see from that computer drawing. As mentioned buy new windows 6" smaller or You could fibre glass the top section on too the existing window cill and then buy some larger white pvc. cover board, and fashion a new cill & flashing and stick it on top of your existing cill, but it will be a bodge up job. Or take the roof down and do it again.
Lower the pitch of the roof so it finishes further below the window and have a zinc roof which will cope with the low pitch :D
Now then , now then , HMK - what about a metal flat portion and a tray under the windows
M8 get a lead burner to come look at it before you go start chopping things down not a roofer
