I'm surprised to see negative comments about Roofkrete. I've had it fitted on my extension 4 1/2 years ago, and yes I've had problems, but not due to Roofkrete. The problems were due to my builders who unbeknown to me decided on some outrageous cost-cutting measures, - e.g. no flashing on the upper edge of the skirting on the vertical wall - they only cemented over it with ordinary mortar mix, and after a while, this separated from the wall and started leaking. Another outrage was that they failed to put a damp-proof barrier across the parapet walls, and water was getting in through gaps between the capping stones, and such-like.
I've checked out the science, and it makes good sense - Roofkrete is a ferro-cement, hence the flexibility and increasing strength over time, as the crystals develop. It's not a DIY job by any means, the installer needs to understand the concepts, and mine clearly didn't.
I have another flat roof, done by conventional means, which needs replacing, and Roofkrete is a serious contender, even though this roof will never be walked on, and won't not need the strength to survive stiletto heels.
On a balcony or a terrace, Roofkrete is a great choice. It is more labour intensive than just pouring on a membrane, but once you've done it, that's it, you can forget maintenance, that is a significant time saving over the lifetime of a building. Just make sure you get qualified installers.
