Hi folks
new to this forum but looks good. I need some help please. I have a Sabre HE 35 boiler that was new in Dec 2008, it has run perfect since it was fitted, butt yesterday the boilers red light came on, no heating or hot water, but the fan inside the boiler was still running, so I switched it of at the boiler switch then back on and away it went, until this morning tried the same but nothing but the fan. I removed the outer white casing there was nothing lose, looks ok, So while it was still on the on position with the fan still on I unclipped the lower clips on the front case with the glass window, pulled the bottom of the panel out slightly, then it sucked a wee bit more air in then bingo click, click away she goes Strange! then later when the heating gets up to temp; she wont come back on again unless I unclip and lift the front cover again and so on.
I have misplaced the instruction manual for the boiler so can anyone help.
PS she has not been serviced from new yet.
thanks Wullie1
thanks Wullie1
