Samsung C61R2AEE Wiring
21 Dec 2009
Kent
Hi Guys,
Trying to install a samsung C61R2AEE electric hob. The manual for it is below:
http://downloadcenter.samsung.com/c...4187_C_Top_MID]_C61RAAST_XEU-00031A-01_EN.pdf
Having a few problems with the wiring diagram. It seems to have earth, neutal and 1,2,3. If i put earth into earth neutral into neutral and the live ito 1, the unit powers up and two of the hobs work fine, the other two wont heat up. I am thinking that maybe there needs to be a link betwen 1 and 2 and 2 and 3, but there isnt any room to link these with the 6mm cable ive used for the incoming.
Is there any chance someone could please take a look at the wiring diagram in the manual and tell me exactly how it should be wired.
Thanks in advance.
Ben
The diagram and write up do say you need connecting links, usually these are supplied (thin copper links that slot in) if not you will need to use links.
The table says for an appliance rated 25A and 32A you need to use a cable larger than 4mm squared but less than 6mm squared (this would be all hobs connected via one supply cable)
In parts of europe cookers can be supplied by 3 phase
Thanks for your reply. No it didnt come with any links unfortunately :(
The cable i need to use for the links, a cant use 6mm as it just wont fit. Would it be possible to use smaller cable? Or buy metal links from somewhere?
Cheers
Ben
Did you manage to fix this in the end? If so, please let me know how!
I am stuck with the same problem!
Thanks,
Ben
Hi Guys,
Same problem here, just purchased this Samsung hob, and need to find these copper links, did anyone have any success in finding them, any info gratefully received, many thanks, Alan,
Many thanks. have just found the links. They are very tiny, and are concealed in the compartment where the wiring connectors are. I can imagine that you would easily not be able to spot them, they are very concealed.
Shall I wire it as 1n or 2n, and what is the difference please, thankyou again, Alan
You need to wire it in as a single phase appliance so 1n
2n is for when you have a 2 or 3 phase supply to the property (not very common in the uk)
I've just found the conectors. Can anyone tell me how they work, fit into the terminals? thanks
Found the Metal Copper U Shape links, but cannot figure out how to fit them.
Anyone know where they go for diagram N1.
