- Joined
- 31 Oct 2015
- Messages
- 55
- Reaction score
- 0
- Country
Hi our floor was done about 7 weeks ago ,I moved a table today and must have caught the floor and it created a hole when I poked the sand away ,I will add pics ,also another spot is crumbly ,the surface is quite dusty when walked on you can feel the grit on your feet .is this normal . Should it be a polished surface as it's quite rough and bitty .i had to chisel a bit away in the corner due to it being a bit higher than our floor and this in areas was a crumbly .hoping it's not been done by a cowboy as job has now been signed off .thankyou . Also on cement that's between brick work should some of that be powdery to touch ,some of it can be scrapped with a nail ..
