it is to seal the joints after construction. was hoping for a cheaper way as i imaging it will take a fair few tubes
But then again using the wrong one will cost more in the long run
I've just looked at a tube of frame fix in my van, it says coverage 6mm bead - approx 11 linear metres.
So, 6'6" is about 2m therefore, one tube should do 5 panels easily.
25 panels x 6 tubes (to be on the top side) of Dow Corning or similar works out at about £25.00 in product, plus a few quid for an applicator gun....1/2 a day to do the job & 30 quid'ish in materials....
