Hi
(I have a triplex (Labgear psw351t) socket that I would like to use in my lounge, with a slave bt socket and 2 satellite sockets, 1 fm, 1DAB, and 1 return.
One of the connections for the satellite is direct from the LNB, the other needs to be a triplex connection, to supply the remaining outlets.
I have 2 direct satellite feeds already to the lounge, the only reason I want to use this socket is to reduce the number of wall boxes.)
I question is, if I connect the coax, from the LNB, into the connection which is supposed to be triplex, will my SKY+ box get a signal. I don't need DAB or FM.
TIA
Bob
TIA
Bob
