I am new to home ownership and the associated problems just wondered if anyone could point me in the right direction any help appreciated.........
I have a saunia duval semia condens F24e boiler in a 2 bed terrace. The hot water works fine and the boiler fires up nicely however the heating seems to be playing up. If I flick the heating onto constant the gas fires up and continues until 85 (presumably degrees celcius) and then cuts out. The radiators are not warming at all. It worked fine up until recently and no one has changed the settings. It is set to winter use, water temp high heating temp high and I have set the thermostat to a low temp.
I guess it will be an engineer call out but it is entirely possible that I have missed something very obvious.
cheers
cheers
