hello can anyone help with the above boiler which worked fine last night but today won't fire either by using the hot water or central heating. When you trigger the boiler by either method the extractor fan on the top of the boiler locks up at the point of ignition. i have blown through the clear and red pipes that fit between the fan housing and air pressure switch, they all seem clear. the same thing happened a year ago and was down to the pipes in the fan housing being blocked.
any suggestions greatly appreciated.....
