Hi there
First time posting here and I'm hoping/begging you guys can help me !!
I have a SAUNIER DUVAL F24e boiler in our flat. We have been refurbishing the flat and replacing the radiators along the way.
A few months back I replaced a few radiators and I remember that I had problems getting the boiler to kick back in. I filled it, drained it, topped up, bled the air etc etc and eventually it came back on... after a few days.
I have just replaced the last two radiators and once again have a similar problem. I have re-filled with water, bled the air from the radiators, run the hot tap for a minute or two and got the pressure up to what it should be.
However if i turn on the heating or hot water, it seems to call for hot water as you can here the boiler whirring BUT it then displays the fault light after about 10seconds and does not fire up.
It doesn't even try to fire up as I cant hear the clicking and the pressure isn't dropping so I cant figure it out.
It was working fine prior to connecting the radiators and as the pressure seems fine, I'm presuming that theres not a leak?!
The problem wouldn't be quite so bad but I can't get hot water and my girlfriend is quickly running out of patience.
Any thoughts, hints, tips would be amazing and you would make me a happy man.
Thanks in advance
Antony
Thanks in advance
Antony
